Creating image prop objects
             Command  |
             Path  |
             Create Image Prop  |
             Model  |
You can insert “prop” objects made from imported images, such as trees, people, signs, and cars, to make a model look more realistic. An image prop must be in one of the formats listed in Using an image in a texture shader. Most image-based textures are automatically compressed when imported into a Vectorworks file. Imported JPG files retain the original JPG data; all other image files are compressed using lossless PNG format.
For proper display when rendered, an image prop should have a fill style other than None in the Attributes palette.
An image imported for use as a prop is saved as a texture resource. Various libraries of image prop resources are provided in the Vectorworks Libraries (see Concept: Resource libraries).
To add an image prop:
Select the command.
If a resource with an image is already present in the file, the Choose Prop Image dialog box opens.
             Parameter  |
             Description  |
             Import an Image File  |
             Imports a new image; proceed to step 3  |
             Reuse an Image from Another Resource  |
             Reuses a previously imported image; select the resource that contains the image; proceed to step 4  |
Select the desired image file in the Import Image Document dialog box. Click Open.
The Image Prop Options dialog box opens. Specify the parameters for the image prop.
             Parameter  |
             Description  |
             Name  |
             Specify a name for the image prop (used for the texture and symbol name)  |
             Dimensions  |
             Specifies the image prop’s height and width values  |
             Lock Aspect Ratio  |
             Maintains the image’s aspect ratio when selected; editing one dimension automatically changes the other  |
             Mask Options  |
             No Mask  |
             Specifies that no image masking is to be used for the imported image  |
             Use Mask  |
             Specifies that image masking is to be used; click Create Mask to specify the mask image and properties as described in Transparency shader (Image Mask option)  |
             Crossed Planes  |
             Creates the illusion of object fullness by creating two image planes at a 90 degree angle to each other
             Constant Reflectivity  |
             Excludes the prop from the effects of light objects placed in the drawing; this is useful for images that already contain shadowed areas  |
             Create Plug-In Object  |
             Creates a plug-in object out of the prop; this allows the prop to be resized and automatically rotated  |
             Auto Rotate to Viewer  |
             Adjusts the plug-in object so that it is always rendered facing the viewer. Select Auto Rotate to Viewer for crossed plane images, so that the crossed planes cannot be detected.  |
             Create Symbol  |
             Creates a symbol from the image prop; the image prop name is automatically assigned as the symbol name. Generating the image prop as a symbol allows the image prop to be easily re-inserted in the drawing.  |
The image prop symbol parameters can be edited from the Object Info palette. In the Resource Manager and Resource Selector, the image prop is listed as a symbol/plug-in object, if selected at creation. In addition, a texture is created for use by the image prop. Both the texture and, if created, the symbol/plug-in object, are assigned the name provided in the Image Prop Options dialog box.
When scaling image prop symbols, the height is scaled differently depending on the view. In Top/Plan view, the Y scaling factor determines the height; in 3D views, the Z scaling factor determines the height. Changing the Y scaling factor shows no effect on image prop symbols in 3D, but their height scales accordingly in Top/Plan view. See Scaling symbols from the Object Info palette for more information.
